Hi @Sudipta_Ghorui. At the moment, you can’t expose new items to PaperUI. This had to be turned off due to database issues that were crashing myopenhab.org.
If your goal was to use a system like IFTTT, then you unfortunately won’t have any luck at the moment. However, you shouldn’t need to expose items via PaperUI for Alexa or Google Assistant to work, since they use tags in the item definitions.
