Hi I setup an openhab service and tried to create items. At first it works then i wanted to connect it with my mqtt server. Thats the mqtt.cfg
xively.url=tcp://<broker>:1883
The Item looks like this:
Switch Bouncer "occupied" {mqtt=">[xively:office/2:command:ON:0], <[xively:office/2:command:OFF:1]"}
and the sitemap looks like this:
sitemap default label="My first sitemap"{
Switch item=Bouncer
In my head it should be working but I tried it so many times and didn’t get any results.
Can someone help me?
Best Regards
John
rossko57
(Rossko57)
May 6, 2019, 11:37am
2
Have you installed the MQTT biding to openHAB? Important - which version?
@rossko57
Openhab version 2.4.0
I have installed the openhab-binding-mqtt through the paper UI.
rossko57
(Rossko57)
May 6, 2019, 12:27pm
4
Sounds like you probably have the “native” version 2.x of the MQTT binding then.
Your Item binding setup is for 1.x version and won’t work. You need to use things and channels with the 2 version.
https://www.openhab.org/addons/bindings/mqtt.generic/
@rossko57
Thanks for the information. I tried another approach:
The Item looks this now
Switch Bouncer "Office 2" {channel="mqtt:topic:office:office_2:occupied_office"}
and this is my things file:
Bridge mqtt:broker:office "MQTT Office" [ host="ip", port=1883] {
Thing topic office_2 "Office 2" @ "OnOff" {
Channels:
Type switch : occupied_office [stateTopic="office/2", commandTopic="office/2/command", on="0", off="1"]
This doesn’t really work well. What did i overlooked?
rossko57
(Rossko57)
May 6, 2019, 2:13pm
6
I cannot help further with MQTT, someone else’s turn.
It may help if you expand on “doesn’t really work well” - what do you see in events.log and openhab.log, what does your MQTT broker think?
It is a MQTT/OH Bug, i have to update on 2.5 or restart the application.
Here the Thread:
Cosmetic. You need to restart openHAB after changing the textual configuration file containing the broker definition.
