- Platform information:
- Hardware: VM 2 CPU/2 GB RAM / 50GB HDD
- OS: fedora 29 ( 4.18.18-300.fc29.x86_64)
- Java Runtime Environment:
java-11-openjdk-headless-11.0.ea.28-2.fc29.x86_64
java-1.8.0-openjdk-headless-1.8.0.191.b12-8.fc29.x86_64
java-1.8.0-openjdk-1.8.0.191.b12-8.fc29.x86_64
javapackages-filesystem-5.3.0-1.fc29.noarch
java-11-openjdk-11.0.ea.28-2.fc29.x86_64
java-1.8.0-openjdk-devel-1.8.0.191.b12-8.fc29.x86_64
- openHAB version:
openhab2-2.3.0-1.noarch
openhab2-addons-2.3.0-1.noarch
- Issue of the topic: Openhab2 dont send data to influxdb
- Please post configurations (if applicable):
Good day!
Today i installed openhab2+influxdb and configured it (use this instruction InfluxDB+Grafana persistence and graphing)
What works on my installation:
- Openhab2 works and collecting data from xiaomi gateway (sensors, door sensor)
tail -f /var/log/openhab2/events.log
2018-11-18 17:41:33.399 [vent.ItemStateChangedEvent] - mihome_sensor_weather_v1_158d00027435dc_temperature changed from 28.84000015258789 to 28.34000015258789 2018-11-18 17:41:33.405 [vent.ItemStateChangedEvent] - mihome_sensor_weather_v1_158d00027435dc_humidity changed from 28.280000686645508 to 29.059999465942383 2018-11-18 17:41:33.433 [vent.ItemStateChangedEvent] - mihome_sensor_weather_v1_158d00027435dc_pressure changed from 99.01000213623047 to 99.0199966430664
Influxdb work as service. I used this script for check my installation https://gist.github.com/ThomDietrich/ff836dbe0f0eaa2c5270a846a963893b . It works and i can use data in grafana
Grafana already worked because i used it for zabbix
My configs:
part http /etc/influxdb/influxdb.conf
[http]
enabled = true
bind-address = “:8086”
auth-enabled = true
/etc/openhab2/persistence/influxdb.persist
Strategies {
everyHour : “0 0 * * * ?” //self defined strategies
everyDay : “0 0 0 * * ?”
// if no strategy is specified for an Item entry below, the default list will be used
default = everyChange
Items {
group* : strategy = everyChange, restoreOnStartup //persist all direct members of the group ‘group’
item : strategy = everyChange, everyHour // persist the item ‘item’
otherItem // no strategy set, so use default strategy for item ‘otherItem’
* : strategy = everyChange // persist every item
/etc/openhab2/services/influxdb.cfg
url=http://127.0.0.1:8086
user=openhab
password=***
db=openhab_db
retentionPolicy=autogen
Also i change default persistence to influxdb Configuration->System->Persistence and check cli access with this commands
influx -username openhab -password *** -host localhost
Why openhab dont want push data to influxdb?
