i need some help to create a rule that will open my garage door before I get home.
i use the icloud binding to get the location of my phone.
in the logs i get this status of my phone: IphoneSeIPhoneSE_DistanceFromHome changed from 10733.214501955184 to 1769.8338866501367, in the gui i see only 1769 m.
i created a rule with the experimental rule engine
Sorry, don’t use that rule engine, can’t help much.
Then your initial trigger for the rule does not work, what happens if you manually change the switch (or whatever you are using, can’t see from your screenshot).
Try to insert some loginfo’s (don’t know if that is possible with that rule engine).
