Platform information:
- Hardware: Intel i7-4790K
- OS: Windows 8.1 Pro - 64bit
- Java Runtime Environment: jdk1.8.0_181
- openHAB version: 2.3.0
Issue of the topic: I am trying to configure ModBus serial binding for openhub, but it fail to connect to the COM port. I tried connecting to Arduino ModBus slave as well as to mod_RSsim through Null-modem emulator (com0com).
I have clean OpenHab instalation with ModBus binding installed using paper UI (binding-modbus1 - 1.12.0).
I have changed the modbus.cfg file and added to the end of the dovcument:
serial.slave1.connection=COM4
serial.slave1.type=coil
serial.slave1.lenght=1
I have created home.items file and added switch item:
Switch MB_LED "LED" (All){modbus="slave1:0"}
I have created home.sitemap and added frame:
sitemap demo label="My home automation" {
Frame {
Switch item= MB_LED
When I start OpenHab no connection happening and there is log file report below:
2018-07-27 17:20:30.104 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-07-27 17:20:31.932 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.127:8090
2018-07-27 17:20:31.933 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.127:8443
2018-07-27 17:20:33.289 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.items'
2018-07-27 17:20:33.785 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-07-27 17:20:33.949 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
2018-07-27 17:20:34.428 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-07-27 17:20:34.459 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-07-27 17:20:34.471 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-07-27 17:20:34.492 [INFO ] [sysfs.internal.SysfsUsbSerialScanner] - Cannot perform scans with this configuration: sysfsTtyDevicesDirectory: /sys/class/tty, devDirectory: /dev
2018-07-27 17:20:34.495 [INFO ] [sysfs.internal.SysfsUsbSerialScanner] - Cannot perform scans with this configuration: sysfsTtyDevicesDirectory: /sys/class/tty, devDirectory: /dev
2018-07-27 17:20:34.497 [INFO ] [sfs.internal.PollingUsbSerialScanner] - Do not start background scanning, as the configured USB-Serial scanner cannot perform scans on this system
2018-07-27 17:20:34.498 [INFO ] [sfs.internal.PollingUsbSerialScanner] - Do not start background scanning, as the configured USB-Serial scanner cannot perform scans on this system
2018-07-27 17:20:34.537 [INFO ] [b.core.service.AbstractActiveService] - Modbus Polling Service has been started
2018-07-27 17:20:36.331 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 1/3 error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Request: net.wimpi.modbus.msg.ReadCoilsRequest@aa5eb18 (unit id 1 & transaction 1). Serial parameters: SerialParameters@5fc22def[portName=COM4,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=ascii,echo=false,receiveTimeoutMillis=1500]
2018-07-27 17:20:37.868 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 2/3 error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Request: net.wimpi.modbus.msg.ReadCoilsRequest@aa5eb18 (unit id 1 & transaction 2). Serial parameters: SerialParameters@5fc22def[portName=COM4,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=ascii,echo=false,receiveTimeoutMillis=1500]
2018-07-27 17:20:39.405 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 3/3 error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Request: net.wimpi.modbus.msg.ReadCoilsRequest@aa5eb18 (unit id 1 & transaction 3). Serial parameters: SerialParameters@5fc22def[portName=COM4,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=ascii,echo=false,receiveTimeoutMillis=1500]
2018-07-27 17:20:39.405 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute reached max tries 3, throwing last error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Request: net.wimpi.modbus.msg.ReadCoilsRequest@aa5eb18 (unit id 1 & transaction 3). Serial parameters: SerialParameters@5fc22def[portName=COM4,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=ascii,echo=false,receiveTimeoutMillis=1500]
2018-07-27 17:20:39.405 [ERROR] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (slave1): Error getting modbus data for request net.wimpi.modbus.msg.ReadCoilsRequest@aa5eb18. Error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Endpoint ModbusSerialSlaveEndpoint@25e4957f[portName=COM4]. Connection: SerialConnection@5053abb1[portName=COM4,port=//./COM4]
2018-07-27 17:20:41.120 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 1/3 error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Request: net.wimpi.modbus.msg.ReadCoilsRequest@50d0c779 (unit id 1 & transaction 4). Serial parameters: SerialParameters@5fc22def[portName=COM4,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=ascii,echo=false,receiveTimeoutMillis=1500]
2018-07-27 17:20:42.657 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 2/3 error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Request: net.wimpi.modbus.msg.ReadCoilsRequest@50d0c779 (unit id 1 & transaction 5). Serial parameters: SerialParameters@5fc22def[portName=COM4,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=ascii,echo=false,receiveTimeoutMillis=1500]
2018-07-27 17:20:44.194 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 3/3 error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Request: net.wimpi.modbus.msg.ReadCoilsRequest@50d0c779 (unit id 1 & transaction 6). Serial parameters: SerialParameters@5fc22def[portName=COM4,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=ascii,echo=false,receiveTimeoutMillis=1500]
2018-07-27 17:20:44.194 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute reached max tries 3, throwing last error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Request: net.wimpi.modbus.msg.ReadCoilsRequest@50d0c779 (unit id 1 & transaction 6). Serial parameters: SerialParameters@5fc22def[portName=COM4,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=ascii,echo=false,receiveTimeoutMillis=1500]
2018-07-27 17:20:44.194 [ERROR] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (slave1): Error getting modbus data for request net.wimpi.modbus.msg.ReadCoilsRequest@50d0c779. Error: readResponse I/O exception - failed to read: readResponse: I/O exception - Serial port timeout.. Endpoint ModbusSerialSlaveEndpoint@25e4957f[portName=COM4]. Connection: SerialConnection@1e333c05[portName=COM4,port=//./COM4]
com0com is set to virtual port pair COM4-COM5.
mod_RSsim is connected to COM5; baud rate 9600; parity:none; data bits 8; stop bits 1; RTS control - disable.
What am I doing wrong?
Thank you!
