I have openHAB2 on Raspberry Pi 2 and connect to /dev/USB0 converter RS485 to USB and line A and B is connested to MAX485 and from MAX485 to RX and TX and DE PIN 2 to Arduino with sketch:
#include <ModbusRtu.h>
uint16_t au16data[1];
Modbus slave(1,0,2);
void setup() {
pinMode(11, OUTPUT);
digitalWrite(11, LOW );
slave.begin( 19200 );
au16data[0] = 1;
void loop() {
if (slave.poll( au16data, 1 ))
digitalWrite( 11, bitRead( au16data[0], 0 ));
and it’s work fine when is connected to my PC whit software ModbusMaster but when is connected to Raspberry Pi and start openHAB2 snapshot with configuration in /opt/openhab2/conf/services/modbus.cfg
poll=5000
serial.slave1.connection=/dev/ttyUSB0:19200:8:even:1:rtu
serial.slave1.id=1
serial.slave1.start=0
serial.slave1.length=1
serial.slave1.type=coil
and items:
Group FF_Modbus "Modbus" (All)
Switch MB_CL16 "CL16" (FF_Modbus){modbus="slave1:0"}
and sitemap:
sitemap demo label="Main Menu"
Frame {
Group item=FF_Modbus icon="attic"
Frame {
Switch item= MB_CL16
i have problem in my logs:
2016-10-06 13:14:50.624 [WARN ] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (slave1) not connected -- aborting read request net.wimpi.modbus.msg.ReadCoilsRequest@993a26. Endpoint ModbusSerialSlaveEndpoint@13b67c4[portName=/dev/ttyUSB0]
2016-10-06 13:14:55.646 [ERROR] [et.wimpi.modbus.net.SerialConnection] - Could not get port identifier, maybe insufficient permissions. null
2016-10-06 13:14:55.656 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/3 error: Could not get port identifier, maybe insufficient permissions. null. Connection SerialConnection@1661edd[portName=/dev/ttyUSB0,port=<null>]. Endpoint ModbusSerialSlaveEndpoint@13b67c4[portName=/dev/ttyUSB0]
2016-10-06 13:14:55.712 [ERROR] [et.wimpi.modbus.net.SerialConnection] - Could not get port identifier, maybe insufficient permissions. null
2016-10-06 13:14:55.719 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 2/3 error: Could not get port identifier, maybe insufficient permissions. null. Connection SerialConnection@1661edd[portName=/dev/ttyUSB0,port=<null>]. Endpoint ModbusSerialSlaveEndpoint@13b67c4[portName=/dev/ttyUSB0]
2016-10-06 13:14:55.776 [ERROR] [et.wimpi.modbus.net.SerialConnection] - Could not get port identifier, maybe insufficient permissions. null
2016-10-06 13:14:55.782 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 3/3 error: Could not get port identifier, maybe insufficient permissions. null. Connection SerialConnection@1661edd[portName=/dev/ttyUSB0,port=<null>]. Endpoint ModbusSerialSlaveEndpoint@13b67c4[portName=/dev/ttyUSB0]
2016-10-06 13:14:55.788 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - re-connect reached max tries 3, throwing last error: Could not get port identifier, maybe insufficient permissions. null. Connection SerialConnection@1661edd[portName=/dev/ttyUSB0,port=<null>]. Endpoint ModbusSerialSlaveEndpoint@13b67c4[portName=/dev/ttyUSB0]
2016-10-06 13:14:55.794 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - Error connecting connection SerialConnection@1661edd[portName=/dev/ttyUSB0,port=<null>] for endpoint ModbusSerialSlaveEndpoint@13b67c4[portName=/dev/ttyUSB0]: Could not get port identifier, maybe insufficient permissions. null
2016-10-06 13:14:55.802 [WARN ] [.binding.modbus.internal.ModbusSlave] - ModbusSlave (slave1): Error getting a new connection for endpoint ModbusSerialSlaveEndpoint@13b67c4[portName=/dev/ttyUSB0]. Error was: Unable to validate object
I do not know what I can do to it worked, please help
My USB permissions:
pi@raspberrypi /dev $ ls -la |grep USB
crw-rw---T 1 root dialout 188, 0 Oct 6 12:28 ttyUSB0
