[SOLVED] Openhab2 not updating power status of sonoff on reboot
Hi everyone. I am running openhab2 on raspberry-pi 3. I am struggling with openhab not updating the power status of sonoff basic on reboot. Is this normal? Please suggest. I have tried to get the switch status in logs, it says NULL.
That is pretty normal :grin:
Read a little bit about persistence and restoreOnStartup.
For your specific case I recommend using MapDB.
hey, many thanks for the quick reply. I found a simple cheat solution to this.
I created a rule that runs when “System started” and added this http command
sendHttpGetRequest(“http://192.168.0.xxx/cm?cmnd=power”)
here xxx is my sonoff ip.
And now openhab shows the sonoff power state correctly on reboot.
Could you share exactly your rule for this?
thank you
sorry, I am quite a newbie. Could someone explain exactly how to create a rule that updates the sonoff power status on reboot?
You need to puzzle both pieces (from the rules link and @akhilmagotra’s example) together:
rule "Speedtest init"
    System started
    createTimer(now.plusSeconds(30), [|
        if (Speedtest_Summary.state == NULL || Speedtest_Summary.state == "") Speedtest_Summary.postUpdate("unknown")
rule "update power"
    System started
The sendHttpGetRequest syntax depends on the firmware you are using on your device.
