[SOLVED] Openhab2 sonoff th16 AM2301-temperature reading --mqtt
02:02:15 MQT: tele/sonoff/SENSOR = {“Time”:“2018-01-03T02:02:15”,“AM2301”:{“Temperature”:23.8,“Humidity”:59.1},“TempUnit”:“C”}
i cant read the temperature on openhab…can somebody Show a sitemap and item for this…thanks
buy the way the switch Works fine with mqtt…
You will need the JSONPath Transformation add-on installed.
Your .items file will look like this:
Number SonoffTemp "Sonoff Temperature [%.1f °C]" <temperature> {mqtt="<[broker:tele/sonoff/SENSOR:state:JSONPATH($.AM2301.Temperature)]"}
And Sitemap:
Text item=SonoffTemp
Hope this helps you understand a little more.
thank u so so much…it work exilent
Hey Gary, i have been messing with this for days. This is where I am. I have the same thing as Ceyhun. My switch works just fine with the th16. I show the temp and humidity in the tasmato console.
This is some of what I cobbled together from threads including your line:
String Indoor_State "[%s]" (startpersist) {mqtt="<[broker:stat/sonoff-00th161/POWER:state:default]"}
Number Indoor_Temperature "Indoor Temperature [%.1f °F]" <temperature> {mqtt="<[broker:tele/sonoff-00th161/SENSOR:state:JSONPATH($.AM2301.Temperature)]"}
Number Indoor_Humidity "Humidity [%d %%]" <humidity>  {mqtt="<[broker:tele/sonoff-00th161/AM2301/HUMIDITY:state:default]"}
site map:
 Text item=Indoor_Temperature
 Text item=Indoor_Humidity
still dont get either to show up.
thanks!
just as i say that it shows up. lol. but its not 20 degrees F in my basement. i guess its showing as C. how do you change that? thought i did it with the command in there.
grrr, now I added this and I dont get either of the readings:
Number Indoor_Humidity "Humidity [%d %%]" <humidity>  {mqtt="<[broker:tele/sonoff-00th161/SENSOR:state:JSONPATH($.AM2301.Humidity)]"}
Every now and then the results show up but then disappear.
