I bought my unit on banggood, my friend on the gearbest. The question is not “where” but “when”. You should wait for discounts or sales ;).
Ok, it’s easy to distinguish them. Better buy mijia (in my opinion).
It is not mandatory to sick to stock version. Currently, I’ve the latest version of mi home app on my phone and the latest firmware on the gateway. IMPORTANT: enable development options and “additional communication” before updating the gateway firmware or you will have to disassemble the device and solder things.
If you are afraid of soldering, stay on the default firmware.
I tried, but without success. I did not spend too much time on this attack vector.
I also thought to create fake xiaomi http server (via the fake local-dns server or iptables rules) and serve the old firmware with the server. Then wait for the new official firmware from xiaomi. Turn on my spoofed server and run the upgrade from the android/ios app. Unfortunately, I did not have enough time to configure and prepare the entire attack.
Hi. I can’t read or send any commands to the gateway.
Here are my steps:
Connect USB-TTL Serial Modul FT232RL GND to GND on Gateway and RX from UART to TX on Gateway
Plug in USB Modul to PC --> red light in corner of module turns on
Turn on Gateway --> flashes blue for a few seconds, then turns off
In Putty, select COM3 (Speed 9600, Data bits 8, Stop bits 1, Parity None, Flow control None) --> Open
Connect TX from UART to RX on Gateway. No additional LED turn on on UART
In the Putty window I now sporadically see some cryptical characters showing up, but nothing like “You will see all messages of gateway.” Also sending a command does not do anything.
Does anyone have an idea what I’m doing wrong? Thanks a lot
Hi @D1rk,
Speed should be 115200 bauds, I’ve figured it out by trying different speed and with 115200 you will see some readable characters ie : a boot sequence like this
mi_i2s_init ok I2S_IRQn= 11
player starting......
SetFreq 44100
mi_i2s_set_freq 44.1KHz
gpio stat:1
audio mixer init done
find 0 channels on flash,temp_play=0
find_list = -1
dac_freq_set_ = 44100 , 44100
Creat Thread mi_ipc_looper
not sure about the other config (data bits, stop … ) as I used the a mac os terminal with the ‘screen’ command, so should be the defaults :
Flow control can be also completely off.
Btw: I am not sure if the old trick with the firmware updates MITM from my Defcon Talk still works or if they patched the MD5 checksum check…
Hi guys. Thanks a lot for your help. Christian’s settings did work and the Hub was discovered in OH after waiting for a few minutes. Now I will disconnect it from the manufacturer cloud so that they cannot make any unwanted changes In the next days I will try to connect some additional sensors.
Is this for sure ? I have 2 gateway both with round text and both dev mode enable, first one is lock (port 9898 not open) but I’ve enable dev mode after firmware updates. Second is not lock, I currently use it with my openhab but I’m afraid to make firmware updates. (I need to do updates because Aqara cube doesn’t work fine). Is it confirmed that I can make updates on this one ? Is anyone here have done the firmware updates after enabling dev mode on this version of the gateway and still have the port 9898 open ?
