If I understood correctly, openHAB3 automatically persists item states with reasonable default settings if a default persistence service is configured.
This inherently brings the ability to analyze historic item state without any hassle of configuring it manually. This is quite good. Love it!
Second benefit is the restore on startup which works automatically too…
This might we wanted in most but not all cases.
What, if I don’t want an item stating a “historic” state?
Think about:
measurements
alarms
presence
If such items got “restored on startup” they may show wrong data. In some cases it would be better letting the item NULL until an actual status update/command got received instead of setting the item to an old and probably wrong state. Better to have no state than a wrong state.
Question: How to change the default restore-on-startup behaviour in openHAB3 for specific items preventing them from been restored with potentially wrong historic states?
I think you can create a custom rrd4j.persist that explicitly has no RestoreOnStartup that should override the default behavior.
But I would not mess with it, restore on startup isn’t causing your “wrong” states.
Your rules on startup need to take care to reinitialize/sync state changes that may have happened while OH was down, if they don’t handle that properly that is where the problem is.
Good point. Just thought the same.
Admittedly, I currently trying this out to see how this affects the “default” persisting/restoring behaviour and if this is a way to prevent “restoring” for some items.
Agree basically. But when does the restore on startup happen? So, even if I have a good procedure to initialize my items properly, would’nt restore on startup interfere here nevertheless? If yes, I should be prepared to deal with the “flapping” item state e.g.
from NULL via RESTORED-STATE to CORRECT-STATE
I think, even in case I have sophisticated initialization rules, preventing restore-on-startupfor some crucial items might remain desired
As said above, I’ve tried a manually configured rrd4j.persist to prevent some items from beeing restored on startup.
EDIT: I’ve “reversed” my initial approach with “excluding” some items from been restored. Now I’m putting all items which should be restored in a dedicated group. Here is the updated post:
First, I created an additional group for all items, which should get restored after startup.
Group gRestoreOnStartup
Second, I added a rrd4j.persist file to the persistence folder:
