(SOLVED)OpenHabian 2 MQTT Item
Hi ,i need to use a “switch” item ,but i need a switch like a digital button not to stay ON or OFF,but to give the command and return to the initial state. Any help ? THX
Have you seen
and the autoupdate feature ?
You can also use a proxy switch and a rule that when the switch turns on have it send a command then turn back off. I can provide an example if needed.
Or in the sitemap:
Text item=mySwitch mappings=[ON="ON"]
And the item:
Switch mySwitch { autoupdate="false" }
You can use expire binding
Switch Wallplug_FF_LR_TV "Wallplug TV" <poweroutlet> { channel="zwave:device:bb4d2b80:node30:switch_binary"; expire="1s,command=OFF" }
So many options, the great thing about OH.:grinning: If your just starting out with OH I recommend to try them all. Nothing better for learning than to jump in try a little of everything.
yes pls
It`s not working (my fault probably),i will try whit a rule.This is my Switch :slight_smile:
Switch PowerReleu1 "Power Releu 1" <Power> [ "Switchable" ] {mqtt=">[broker:SmartHome/Power/Releu1:command:ON:Z3ON],>[broker:SmartHome/Power/Releu1:command:OFF:Z3OFF],<[broker:SmartHome/Power/Releu1/state:state:ON:Z3ON],<[broker:SmartHome/Power/Releu1/state:state:OFF:Z3OFF]", autoupdate="false"}
