i have an issue (not critical maybe) since quite a few months.
I am running openhabian 1.4.1-413 and do an update upgrade every now and then.
updating works fine - at the end of the upgrade though I get an error related to mosquitto:
WARNUNG: Die folgenden Pakete können nicht authentifiziert werden!
mosquitto-clients libmosquitto1 mosquitto
E: Es gab Probleme und -y wurde ohne --force-yes verwendet.
FAILED
Which actually means:
WARNING: the following packages could not be authenticated.
mosquitto...
There were problems and -y was used without --force-yes.
So it seems mosquitto has not been upgraded on my system since a few months.
Any suggestions?
1536166926: Config loaded from /etc/mosquitto/mosquitto.conf.
1536166926: Opening ipv4 listen socket on port 1883.
1536166926: Opening ipv6 listen socket on port 1883.
1536166926: Opening ipv4 listen socket on port 8883.
1536166926: Opening ipv6 listen socket on port 8883.
1536166926: Error: Address already in use
