[SOLVED] Openhabian Frontail stopped working
I’m running latest openhabian image and stable OH2.2 version on a rpi3. Suddenly the log viewer (frontail) stopped working over night. I run the “sudo systemctl status frontail.service” command and this is the output:
* frontail.service - Frontail openHAB instance, reachable at http://openHABianPi:9001
   Loaded: loaded (/etc/systemd/system/frontail.service; enabled)
   Active: active (running) since fr. 2018-01-05 18:47:25 CET; 503ms ago
     Docs: https://github.com/mthenw/frontail
           https://github.com/openhab/openhabian/issues/28
 Main PID: 17071 (node)
   CGroup: /system.slice/frontail.service
           `-17071 node /usr/bin/frontail --ui-highlight --ui-highlight-preset ./preset/openhab.json -t openhab -l 2000 -n 200 /var/log/openhab2/openhab.log /var/log/openhab2/events.log
jan. 05 18:47:25 openHABianPi systemd[1]: Started Frontail openHAB instance, reachable at http://openHABianPi:9001.
I’ve tried to reinstall it several times through openhabian-config, but the openhab log viewer still doesn’t work. When i press the openhab log viewer in openhabianpi:8080/start/index, I get a “This webpage is not available, ERR_CONNECTION_REFUSED”, as if the web server is not running,
Any ideas on how to solve this?
Best regards
Chris
What happens if you use
Exactly the same :frowning:
Have tried to reboot several times, and now upgraded to OH2 latest snapshot. Still no difference.. The log files are not corrupt, as i can tail the log files from ssh.
What web server is frontail using?
Anyone?
So, I finally figured out this as well. I saw some post on this forum regarding similar problems after upgrading OH2. I stopped OH2 and cleared the cache and tmp folder. Then I opened openhabian-config and run a update. After restarting OH2 everything is working fine! :slight_smile:
