[SOLVED] OpenUV issue on #1524
Hi all,
it seems there is an issue with our OpenUV Binding. tried to reinstall, nothing.
Here the issue:
2019-02-17 15:07:23.118 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
	at org.openhab.binding.openuv.internal.handler.OpenUVReportHandler.scheduleUVMaxEvent(OpenUVReportHandler.java:102) ~[?:?]
	at org.openhab.binding.openuv.internal.handler.OpenUVReportHandler.updateChannels(OpenUVReportHandler.java:130) ~[?:?]
	at org.openhab.binding.openuv.internal.handler.OpenUVReportHandler.lambda$2(OpenUVReportHandler.java:161) ~[?:?]
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
2019-02-17 15:07:23.024 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-02-17 15:07:22.986 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-17 15:07:23.196 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-17 15:07:23.302 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-17 15:07:23.403 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-17 15:07:23.419 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
	at org.openhab.binding.openuv.internal.handler.OpenUVReportHandler.lambda$1(OpenUVReportHandler.java:122) ~[?:?]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:?]
@glhopital maybe this is related to
that should be ok from #1518?
thanks
Andrea
The issue disappear in #1525, back again in #1526:
2019-02-21 12:20:59.548 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 12:20:59.762 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 12:20:59.890 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 12:21:00.012 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 12:21:00.127 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 12:21:01.206 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
The “Local UV Information” is in UNKNOWN state. I’ve already removed and re-added, nothing.
2019-02-21 16:14:55.117 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'openuv:uvreport:local' to inbox.
2019-02-21 16:15:03.272 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 16:15:03.275 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 16:15:03.387 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 16:15:03.390 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 16:15:03.498 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 16:15:03.509 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2019-02-21 16:15:49.071 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
Trying debugging the issue.
@glhopital may I ask your support here?
thanks
Andrea
It has nothing to do with the issue you mentioned.
The error is triggered inside a scheduled job in the binding that crashes the scheduled job. In this case in OpenUVReportHandler.java at line 102.
Looking in the latest source code (and assuming your running the same) it tries to get a value from the data. The NullPointer suggest the data is null. That could mean the json coming from the server could not be parsed which would return null. This could mean or the server could not be reached, or maybe the data format changed, api-key changes, actually it could be anything. The binding has some debug logging. It can log the actual call to the server. Maybe this can be some help. Or also report this as an issue on the openhab2-addons repo as null pointers are bugs.
tadaaaaamm …
2019-02-21 17:29:31.934 [DEBUG] [internal.handler.OpenUVBridgeHandler] - URL = {"error":"Daily API quota exceeded. Add billing details to get 15000 reqs/day or contact support@openuv.io to upgrade to Unlimited Plan."}
Makes no sense for me, as I’ve configured the Binding to contact the service every 30 mins (and the free account is 50 reqs/day).
:frowning:
I will investigate.
thanks
Andrea
