- Platform information:
- Hardware: Rpi4
- OS: Openhabian hassle free installation
Hi Guys,
I installed Openhabian hassle free installation without any problem, and than immediately installed owserver. No other package was installed.
sudo apt-get install owserver owhttpd
Errors were reported during installation
Creating config file /etc/owfs.conf with new version
Setting up libow-3.2-3:armhf (3.2p3+dfsg1-2) ...
Setting up owserver (3.2p3+dfsg1-2) ...
Job for owserver.service failed because the service did not take the steps required by its unit configuration.
See "systemctl status owserver.service" and "journalctl -xe" for details.
invoke-rc.d: initscript owserver, action "start" failed.
● owserver.service - Backend server for 1-wire control
Loaded: loaded (/lib/systemd/system/owserver.service; disabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: protocol) since Thu 2019-11-28 19:37:38 CET; 59ms ago
Docs: man:owserver(1)
Process: 21434 ExecStart=/usr/bin/owserver -c /etc/owfs.conf (code=exited, status=0/SUCCESS)
Main PID: 21434 (code=exited, status=0/SUCCESS)
dpkg: error processing package owserver (--configure):
installed owserver package post-installation script subprocess returned error exit status 1
Setting up owhttpd (3.2p3+dfsg1-2) ...
Created symlink /etc/systemd/system/multi-user.target.wants/owhttpd.service → /lib/systemd/system/owhttpd.service.
Processing triggers for systemd (241-7~deb10u2+rpi1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
Errors were encountered while processing:
owserver
Updating FireMotD available updates count ...
E: Sub-process /usr/bin/dpkg returned an error code (1)
[19:37:53] openhabian@openhab:~$
Despite errors Owserver seemed to be active after installation according to following command
sudo systemctl status owserver.service
After reboot Owserver didn’t start. It was reported “dead”.
Active: inactive (dead)
Could you please help me what is missing to install Owserver correctly?
