Ah, that’s true.
For others with the same problem:
- Execute
$OPENHAB_RUNTIME/bin/client
on your OpenHab server (if Linux). - Connect using
openhab
as user (if asked) andhabopen
as password - execute
bundle:list
- Search for CometVisu in the list and note the number at the beginning of the line
- Execute
bundle:uninstall <thenumber>
(i.e.bundle:uninstall 248
) - Done
I will wait for the next release and hope it will work.
Edit:
After some days I had the problem again and ran the manual uninstallation again. Somehow it was installed again after I installed another plugin. After I re-uninstalled it, I changed to the “User Interfaces” in Paper UI and clicked the uninstall-text on comet visu. Seems like PaperUI installs it again if you uninstall it manually and you are installing something else afterwise.
