How do I connect my LED strip to the system? In the explanation on the site, there are instructions on the lamps and not on the LED strips. I need a specific code and I can not understand what it is
Example
0210 bulb1 “Lamp 1” @ “Kitchen” [lightId = “1”]
And who is the code for light strip, someone has connected and can help?
There is no difference in defining a thing for bulbs or the strips, you will need to find the lightId however, in PaperUI, just like you would for any bulb. I believe the documentation on PaperUI and the binding give examples how to do that.
But in any case, you will need a Hue Hub and the app and add the strip to your Hue system through the app first.
If you already have added your lightstrip to the Hue Bridge via Hue App you will find it there and the corresponding number on the left side. (see screenshot above). This is the light ID.
There are different light types.
Your lightstrip should have type 0210 = extended color light. But type is NOT shown in the Philips Hue App.
But if you want to add it to the .things file, (you need the type, e.g 0210, see here)
then put it there as minimum:
Then it should appear there. Normally it is automatically discovered and already shown in your inbox ( if you didn’t disable
“auto discovery” in your system settings).
