I have got openHAB and pi-hole Running in docker containers and pi-hold is the dns resolver for the network. Since the install of pi-hole openHAB can’t connect myopenhab although I whitelisted myopenhaborg.
Has anyone an idea how to make the connection working again?
i am running pi-hole too, but i do not encounter any problems and have not whitelisted myopenhab.org. Have you tried to reach myopenhab with a ping or something similar?
@nakh_Home No on an different pi (have four or five in spare) with dietPi as distribution
@NSchnitzler If you reach myopenhab in general from your network pihole should be working fine. You wrote that pihole and openhab are o the same system. maybe this system is not resolving dns correctly. from my pihole server it is working. If a ping from the dns server does not work, try to check another adress something like www.heise.de
