[SOLVED] Pilight not working with fresh Openhab 2 image
after successfully running Openhab 1.x for about 2 years w/o ever having to touch anything, in the past month certain things started to fail for me (noticeably the Sonos binding). As according fixes where only produced for OH 2 (and I thought about upgrading anyhow for a while already) I decided to setup my Raspberry freshly (no migration) with the latest Openhabianpi full image setup. Everything went smooth so far and I have my old setup pretty much back up & running.
The only thing I can’t get back to work for the life of me is pilight (which I need for all my 433MHz stuff…). This was such an easy no-brainer in my old setup that I didn’t even backup any of the old configuration. Now I installed the latest version (8.x) and it doesn’t fly. I get the somehow famous “NOTICE: no pilight ssdp connections found” error, and while there are tons of troubleshooting guides around (iptables mods, interface cfg. additions etc.), none of them seem to work for me.
I am just hoping this is a special dependency to the Openhabianpi image that someone else already figured out and might give me the final hint.
Here is my config (receive is on GPIO 2/P27 for me – worked just fine before):
    "devices": {},
    "rules": {},
    "gui": {},
    "settings": {
            "log-level": 6,
            "pid-file": "/var/run/pilight.pid",
            "log-file": "/var/log/pilight.log",
            "standalone": 1,
            "webserver-enable": 0,
            "webserver-root": "/usr/local/share/pilight/webgui",
            "webserver-http-port": 5001,
            "webserver-https-port": 5002,
            "webserver-cache": 1,
            "whitelist": "",
            "gpio-platform": "raspberrypi3"
    "hardware": {
            "433gpio": {
                    "sender": 0,
                    "receiver": 2
    "registry": {
            "webserver": {
                    "ssl": {
                            "certificate": {
                                    "location": "/etc/pilight/pilight.pem"
            "pilight": {
                    "version": {
                            "current": "8.1.4"
pilight-daemon is not complaining (except about the SSDP issue):
[Jan 24 13:51:27:263426] pilight-daemon: DEBUG: loaded storage /usr/local/lib/pilight/storage/json/registry.lua v1.0
[Jan 24 13:51:27:273200] pilight-daemon: DEBUG: loaded storage /usr/local/lib/pilight/storage/json/settings.lua v1.0
[Jan 24 13:51:27:283371] pilight-daemon: DEBUG: loaded event function /usr/local/lib/pilight/functions/random.lua v2.1
[Jan 24 13:51:27:284512] pilight-daemon: DEBUG: loaded event function /usr/local/lib/pilight/functions/max.lua v2.1
[Jan 24 13:51:27:285982] pilight-daemon: DEBUG: loaded event function /usr/local/lib/pilight/functions/date_add.lua v2.0
[Jan 24 13:51:27:286952] pilight-daemon: DEBUG: loaded event function /usr/local/lib/pilight/functions/min.lua v2.1
[Jan 24 13:51:27:287970] pilight-daemon: DEBUG: loaded event function /usr/local/lib/pilight/functions/date_format.lua v1.0
[Jan 24 13:51:27:289703] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/and.lua v1.0
[Jan 24 13:51:27:290671] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/modulus.lua v1.0
[Jan 24 13:51:27:291404] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/le.lua v1.0
[Jan 24 13:51:27:291996] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/concat.lua v1.0
[Jan 24 13:51:27:292918] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/eq.lua v1.0
[Jan 24 13:51:27:293608] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/intdivide.lua v1.0
[Jan 24 13:51:27:294249] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/divide.lua v1.0
[Jan 24 13:51:27:294896] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/or.lua v1.0
[Jan 24 13:51:27:295536] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/lt.lua v1.0
[Jan 24 13:51:27:296135] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/minus.lua v1.0
[Jan 24 13:51:27:296903] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/gt.lua v1.0
[Jan 24 13:51:27:297610] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/multiply.lua v1.0
[Jan 24 13:51:27:298314] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/ge.lua v1.0
[Jan 24 13:51:27:299036] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/ne.lua v1.0
[Jan 24 13:51:27:299758] pilight-daemon: DEBUG: loaded event operator /usr/local/lib/pilight/operators/plus.lua v1.0
[Jan 24 13:51:27:301172] pilight-daemon: DEBUG: loaded event action /usr/local/lib/pilight/actions/pushover.lua v1.0
[Jan 24 13:51:27:303886] pilight-daemon: DEBUG: loaded event action /usr/local/lib/pilight/actions/switch.lua v4.1
[Jan 24 13:51:27:305623] pilight-daemon: DEBUG: loaded event action /usr/local/lib/pilight/actions/pushbullet.lua v1.0
[Jan 24 13:51:27:307378] pilight-daemon: DEBUG: loaded event action /usr/local/lib/pilight/actions/sendmail.lua v4.1
[Jan 24 13:51:27:310857] pilight-daemon: DEBUG: loaded event action /usr/local/lib/pilight/actions/label.lua v4.1
[Jan 24 13:51:27:312797] pilight-daemon: DEBUG: loaded event action /usr/local/lib/pilight/actions/toggle.lua v4.1
[Jan 24 13:51:27:316735] pilight-daemon: DEBUG: loaded event action /usr/local/lib/pilight/actions/dim.lua v4.1
[Jan 24 13:51:27:322887] pilight-daemon: INFO: version v8.1.4
[Jan 24 13:51:27:346507] pilight-daemon: INFO: daemon listening to port: 35435
[Jan 24 13:51:27:347922] pilight-daemon: DEBUG: new thread socket, 1 thread running
[Jan 24 13:51:27:348070] pilight-daemon: DEBUG: new thread sender, 2 threads running
[Jan 24 13:51:27:348183] pilight-daemon: DEBUG: new thread broadcaster, 3 threads running
[Jan 24 13:51:27:348339] pilight-daemon: INFO: new client, ip: 127.0.0.1, port: 57784
[Jan 24 13:51:27:348367] pilight-daemon: DEBUG: client fd: 12
[Jan 24 13:51:27:348393] pilight-daemon: DEBUG: client id: 1
[Jan 24 13:51:27:353991] pilight-daemon: DEBUG: new thread receive parser, 4 threads running
[Jan 24 13:51:27:354218] pilight-daemon: DEBUG: new thread events client, 5 threads running
[Jan 24 13:51:27:354714] pilight-daemon: DEBUG: ssdp sent search
[Jan 24 13:51:27:354958] pilight-daemon: DEBUG: new thread events loop, 6 threads running
[Jan 24 13:51:27:458980] pilight-daemon: NOTICE: no pilight ssdp connections found
[Jan 24 13:51:27:459492] pilight-daemon: INFO: new client, ip: 127.0.0.1, port: 57786
[Jan 24 13:51:27:459536] pilight-daemon: DEBUG: client fd: 15
[Jan 24 13:51:27:459560] pilight-daemon: DEBUG: client id: 2
[Jan 24 13:51:27:459797] pilight-daemon: DEBUG: socket recv: {"action":"identify","options":{"config":1,"receiver":1},"media":"all"}
[Jan 24 13:51:27:459901] pilight-daemon: DEBUG: socket write succeeded: {"status":"success"}
[Jan 24 13:51:27:459963] pilight-daemon: DEBUG: socket write succeeded: {"action":"identify","options":{"config":1,"receiver":1},"media":"all"}
Any information appreciated – I am completely stuck!
Thanks, Hans-J.
Answering myself :wink:
Setting “Standalone” to 0 (in config.json) did the trick finally…
Thank you very much for sharing your solution!
