I have worked out how to reference sitemaps with a different name to demo.sitemap but I can’t find where I can set things up so that for my items I can used a different name to demo.items.
You can have as many xxx.items files as you wish. All files xxx.items in the /items/ folder will be used, there is no selection tool. If you need to ‘disable’ an items file, you must rename it to changed the extension.
xxx.things files work the same way, if used at all.
