I’m trying to implement OH3 groovy code based on advice given by @rlkoshak in previous posts to simulate presence in the house by looping through an array of lights and setting them to historic states using persistence (I’m using rrd4j).
Here’s my groovy code:
import java.time.ZonedDateTime
// Set number of days in history to simulate
var int days = 7
// Set state of each light to its state number of "days" ago
for(light in ir.getItem("All_Lights").members){
events.sendCommand("light", events.historicState("light",ZonedDateTime.now().minusDays(days)).state)
I get the following error in the events log:
2020-12-20 17:09:18.699 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID ‘fc207fb83e’ failed: javax.script.ScriptException: groovy.lang.MissingMethodException: No signature of method: org.openhab.core.automation.module.script.internal.defaultscope.ScriptBusEvent.historicState() is applicable for argument types: (String, java.time.ZonedDateTime) values: [light, 2020-12-13T17:09:18.542619-05:00[America/Toronto]]
I’m using the persistence extension historicState(), but I don’t think I’m using it correctly.
Maybe it also would have worked by converting the historic state in Groovy to a String first using toString ? That seems to be the main difference between your Groovy and DSL rule.
Just in case someone has the same problem:
There are multiple variants of the events.sendCommand() method
one that takes the name of the item as String and the state as String
one that takes the item (object) and the state as State object
So you can either use events.sendCommand("ItemName", "ON") or you can use events.sendCommand(itemRegistry.get("ItemName"), OFF) using import org.openhab.core.library.types.OnOffType
In this specific case I assume leaving out the quotes on "lights" so it references the current run variable of the for loop instead a static string will do the trick.
