[SOLVED] Problem connecting to cloud
hello
for a few days i cant connect to the cloud, i dont know what happend, but i dont see anything in the log
the key and uuid is ok, also tried few times to uninstall and reinstall, but there is no sign of connection in the log (even when restart openhab serives there is nothing in the log)
log when reinstalling
2018-12-05 02:52:47.115 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2018-12-05 02:52:48.012 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-misc-openhabcloud'
2018-12-05 02:52:48.020 [thome.event.ExtensionEvent] - Extension 'misc-openhabcloud' has been uninstalled.
2018-12-05 02:54:28.097 [thome.event.ExtensionEvent] - Extension 'misc-openhabcloud' has been installed.
its look like the service is not running, only show “Shutting down openHAB Cloud service connection”
i’m using openhab 2.4 (latest snapshot) running on pi3
JAVA ver
openjdk version "1.8.0_152"
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build
1.8.0_152-b76)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed
mode, Evaluation)
please help, thanks
There have been some problems when using the openHAB Cloud connector with anything less than build 161 for JVM (see here: Installation Overview | openHAB)
Upgrade manually to a newer Zulu (since the Azul repos are outdated). Check this out: HowTo: Install Zulu Embedded Java on Raspberry Pi 3 - #48 by Max_G
thanks, update to 191 now its working
dont know what happed and how it work before
