Solved
The adress to the binding was incorrect. Openhab created two bindings for my RFX, and one of them didn’t work ![]()
I have a raspberry 2 running Openhabian and I can’t get my RFX to send signals. I’m getting the error message below.
I think I’m not getting the JD2XX to work and I don’t know how to blacklist the ftdi_sio module (or even if I should)
The only USB I have beside the rfxtrx433e is a Z-wave.
Hope someone can help me ![]()
Regards Fredrik
2018-05-05 09:48:41.462 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Connection to RFXCOM transceiver failed
gnu.io.PortInUseException: org.openhab.binding.rfxcom.internal.connector.RFXComSerialConnector
at gnu.io.CommPortIdentifier.open(CommPortIdentifier.java:459) [25:com.neuronrobotics.nrjavaserial:3.12.0.OH]
at org.openhab.binding.rfxcom.internal.connector.RFXComSerialConnector.connect(RFXComSerialConnector.java:49) [212:org.openhab.binding.rfxcom:2.2.0]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler.connect(RFXComBridgeHandler.java:180) [212:org.openhab.binding.rfxcom:2.2.0]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler.access$8(RFXComBridgeHandler.java:160) [212:org.openhab.binding.rfxcom:2.2.0]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler$1.run(RFXComBridgeHandler.java:153) [212:org.openhab.binding.rfxcom:2.2.0]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
