Ok, after testing everything, it is not working stable…
First, every valve updated the temperature and everything was fine, but then they started to ignore commands or it needed 10 secondes to update.
After some research i found this thread:
So i tried this and updated to the current snapshop (2.5). At the moment, no valve is responding. I followed the instuctions from the thread, i also excluded one valve and included again… Still not working.
I knew using openhab would not be as easy as the fibaro home center or homematic ccu2, but this is realy annoying…
- I updated openhab using the openhabian-config
– switched to stable version - reboot
- removed all zwave things (not the controller)
- deinstalled zwave binding
– installed binding - localizations are set
- added all zwave items again
– they are all recognized as Spirit thermostatic valve
Did i forget something? An important step when updating openhab over the openhabian config?
