[SOLVED] Problem with samba on openhabian
hello
i’m having problem with the samba service openhabian, can’t start the service
 smbd.service - Samba SMB Daemon
 Loaded: loaded (/lib/systemd/system/smbd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2018-12-04 17:39:16 IST; 4min 14s ago
 Docs: man:smbd(8)
       man:samba(7)
       man:smb.conf(5)
 Process: 2839 ExecStart=/usr/sbin/smbd $SMBDOPTIONS (code=exited, status=127)
 Main PID: 2839 (code=exited, status=127)
Dec 04 17:39:16 OPENHAB systemd[1]: Starting Samba SMB Daemon...
Dec 04 17:39:16 OPENHAB smbd[2839]: /usr/sbin/smbd: error while loading shared
libraries: libsecrets3.so.0: cannot open shared object file: No such file or directory
Dec 04 17:39:16 OPENHAB systemd[1]: smbd.service: Main process exited, code=exited,
status=127/n/a
Dec 04 17:39:16 OPENHAB systemd[1]: Failed to start Samba SMB Daemon.
Dec 04 17:39:16 OPENHAB systemd[1]: smbd.service: Unit entered failed state.
Dec 04 17:39:16 OPENHAB systemd[1]: smbd.service: Failed with result 'exit-code'.
● nmbd.service - Samba NMB Daemon
 Loaded: loaded (/lib/systemd/system/nmbd.service; enabled; vendor preset: enabled)
 Active: failed (Result: exit-code) since Tue 2018-12-04 17:28:29 IST; 15min ago
 Docs: man:nmbd(8)
       man:samba(7)
       man:smb.conf(5)
Process: 737 ExecStart=/usr/sbin/nmbd $NMBDOPTIONS (code=exited, status=127)
Main PID: 737 (code=exited, status=127)
 Dec 04 17:28:29 OPENHAB systemd[1]: Starting Samba NMB Daemon...
Dec 04 17:28:29 OPENHAB nmbd[737]: /usr/sbin/nmbd: error while loading shared libraries:
liblibsmb.so.0: cannot open shared object file: No such file or directory
Dec 04 17:28:29 OPENHAB systemd[1]: nmbd.service: Main process exited, code=exited,
status=127/n/a
Dec 04 17:28:29 OPENHAB systemd[1]: Failed to start Samba NMB Daemon.
Dec 04 17:28:29 OPENHAB systemd[1]: nmbd.service: Unit entered failed state.
Dec 04 17:28:29 OPENHAB systemd[1]: nmbd.service: Failed with result 'exit-code'.
please help
thanks
Was samba installed with openhabian-config?
no, it was install with openhabian img file
where is the option to install samba in openhabian-config?
sudo openhabian-config
i mean where it is in the menu of the openhabian-config? i dont see option to install samba
Just checked, I don’t see it either.:roll_eyes:
Have you check the samba config file?
ok i found it, but when trying to install i get this
Copying over custom 'smb.conf'...
Writing authentication data to openHABian default...
/usr/bin/smbpasswd: error while loading shared libraries: liblibsmb.so.0: cannot open shared
$ systemctl enable smbd.service
Synchronizing state of smbd.service with SysV service script with /lib/systemd/systemd-
sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable smbd
 $ systemctl restart smbd.service
Job for smbd.service failed because the control process exited with error code.
See "systemctl status smbd.service" and "journalctl -xe" for details.
Try this
sudo apt-get install samba samba-common-bin
and also use sudo systemctl restart smbd.service
Well openHABian just uses the Raspbian package mechanism to install the (stretch) packages so it’s not really an openHABian issue.
Did you try to do an apt-get dist-upgrade ? What’s in /etc/apt/sources.list, is it still the ‘main’ release train you’re on ? You could try switching to the testing release, but that of course comes with a risk.
Googled a bit and seems this is related to package dependecies. You can try removing everything related to samba and after that upgrade all packages and install samba.
sudo apt-get autoremove samba samba-common
This step uses the autoremove to remove the package.
sudo apt-get purge samba samba-common
This step cleans any configuration file you may have
sudo apt-get update && apt-get upgrade
This updates package lists and upgrades all your installed packages
This installs samba and required packages. This step would be better run from openhabian-config to get shares configured automaticly.
Thanks! this fix my problem!
thank you :grinning:
You’re welcome.
