I have a MQTT device that sends the following message:
fhem/Krigsstigen/pir1/state on-old-for-timer 60
It’s a motion detection (PIR) device from my legacy ELV/FHEM system that I want to use as a contact. I have the following thing definition, that should convert the message to a contact (as described in the docs) :
Thing topic tvrum "TV-rum" @ "Krigsstigen" {
Type contact : motion "TV-rum" [ stateTopic="fhem/Krigsstigen/pir1/state", on="on-old-for-timer 60" ]
However, I get the following error in the logs.
2019-01-07 20:38:30.744 [WARN ] [eneric.internal.generic.ChannelState] - Command 'on-old-for-timer 60' not supported by type 'OpenCloseValue': No enum constant org.eclipse.smarthome.core.library.types.OpenClosedType.on-old-for-timer 60
I guess that the problem is that there is a space in the message, but as I understand from the MQTT standard, this should be allowed. When I use the similar setup for contacts or switches without spaces, it works fine.
Should this be possible with the new binding (i.e. is it a bug?) or am I understanding things wrong?
