I have this item:
Number LightSensorCurrentLevel "_Light Sensor Current Level [%d Lm]" (GDevices,GRoom5) {mios="unit:house,device:137/service/LightSensor1/CurrentLevel"}
Which correctly reports the current light level using this sitemap:
Text item=LightSensorCurrentLevel label="Outside light level"
(it happens to be dark right now)
BUT
when I try to use this rule:
rule LightLevel
Item LightSensorCurrentLevel changed
LightLevelValue = LightSensorCurrentLevel.state
logInfo ("Lighting rule", "New light level: " + LightLevelValue)
if (LightLevelValue < 90){
logInfo ("Lighting rule", "Low light on")
if (LightLevelValue > 92) {
logInfo ("Lighting rule", "High light off")
results in the following error:
2018-12-19 23:31:15.967 [INFO ] [smarthome.model.script.Lighting rule] - New light level: 1
2018-12-19 23:31:15.971 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'LightLevel': An error occurred during the script execution: Could not invoke method: org.eclipse.xtext.xbase.lib.IntegerExtensions.operator_lessThan(int,int) on instance: null
Clearly the value of the item state is not NULL so what am I doing wrong?
