This was the problem I faced updating. I ended up reloading and bringing things in slow.
I know I should not need to do that but it worked. I believe it may have been related to the addons.config file. I plan to update to the actual release but before I do, I want to debug a little first. Seems like something in the apt update is wrong.
that’s strange- the config files
./userdata/config/org/openhab/addons.config and
./conf/services/addons.cfg
has no manual entries, no entries for bindings or GUI.
I know, there was another (temporary) file with my entries. Anybody knows, where I’ll find it?
Can it be, the new Version will ignore this file?
the config files
I know, there was another (temporary) file with my entries. Can it be, the new Version will ignore this file?
Should I try to insert the entry for paperui? Why I can do that?
There is no package listed, the file is not edited;
# The installation package of this openHAB instance
# Note: This is only regarded at the VERY FIRST START of openHAB
# Note: If you want to specify your add-ons yourself through entries below, set the package to "minimal"
# as otherwise your definition might be in conflict with what the installation package defines.
# Optional. If not set, the dashboard (https://<yourserver>:8080/) will ask you to choose a package.
# Valid options:
# - minimal : Installation only with dashboard, but no UIs or other add-ons. Use this for custom setups.
# - simple : Setup for using openHAB purely through UIs - you need to expect MANY constraints in functionality!
# - standard : Default setup for normal users, best for textual setup
# - expert : Setup for expert users, especially for people migrating from openHAB 1.x
# - demo : A demo setup which includes UIs, a few bindings, config files etc.
# See http://docs.openhab.org/configuration/packages.html for a detailed explanation of these packages.
#package = minimal
# Access Remote Add-on Repository
# Defines whether the remote openHAB add-on repository should be used for browsing and installing add-ons.
# This not only makes latest snapshots of add-ons available, it is also required for the installation of
# any legacy 1.x add-on. (default is true)
#remote = true
# Include legacy 1.x bindings. If set to true, it also allows the installation of 1.x bindings for which there is
# already a 2.x version available (requires remote repo access, see above). (default is false)
#legacy = true
# A comma-separated list of bindings to install (e.g. "sonos,knx,zwave")
#binding =
# A comma-separated list of UIs to install (e.g. "basic,paper")
#ui =
# A comma-separated list of persistence services to install (e.g. "rrd4j,jpa")
#persistence =
# A comma-separated list of actions to install (e.g. "mail,pushover")
#action =
# A comma-separated list of transformation services to install (e.g. "map,jsonpath")
#transformation =
# A comma-separated list of voice services to install (e.g. "marytts,freetts")
#voice =
# A comma-separated list of miscellaneous services to install (e.g. "myopenhab")
#misc =
Downgrade to OH version 2.4, after it’s up and running, uninstall restdocs via PaperUI. Stop OH, clean the cache and restart. After its up and running then got to openhabian-config tool and select the option 1, then 2, and 3. After that jump down to “apply improvements” and select option 11, 12, 13 and 14. Now exit the tool and restart OH.
After a few minuets you should have access to PaperUI where you can set you location and add restdocs.
I just tested this on my production server and everything worked.
