[SOLVED] Problems adding KFOB-C Remote Control to openhab2
I cannot get to KFOB-C Remote Control properly recognised.
  1. After repeatedly deleting from inbox factory resetting etc. I have a number of nodes. But I don#t believe that this is a real issue.
  2. The KFOB but it is an unknown device type. I have used the remote keypad to put it in “Management” mode and pressed button 2 to wake it up repeatedly with no joy…
Could someone please provide some pointers…
Regards
Paul
OK I have this working now. I have no idea what I did differently.
Give it a rest for a day then try again..
Quoting Hartmut Schwensen bot@community.openhab.org:
hartmood[1] Hartmut Schwensen[1]
December 14
  Same Issue here - mutliple attempts, multiple resets. Still
pops up as an unknown devices. Does anybody have a clue what is the
right way to do? BTW: Have the Z-Wave Biding from Chris with the
Secure Layer (for the Danalock) installed.
 Visit Topic[2] or reply to this email to respond.
In Reply To
pharmswo[3] Paul[3]
May 31
 To unsubscribe from these emails, click here[4].
Links:
To be honest I dont remember how to reset the keyfob. But the
manual is online somewhere.
I seem to remember removing the device from Hab.And then resetting the
keyfob. (sevveral times…)
Once the keyfob is seen by Hab you need to wake the keyfob up quite a
few times before it is recognised as the keyfob. Be patient! Wake it
up - leave it for awile e.g. 15mins wake it up etc. The wake up
sequence for keyfob is also in the manual -pay attention to what the
manual says about the flashing lights - for reset and for wake up!
December 14
  Hey Paul, OK, thanks, will do. Can you con confirm the
procedure: All buttons 1 seconds, then button 3 then button 4 5
seconds for factory reset. Then pairing with button 1 one second?
In Reply To
pharmswo[3] Paul[3]
December 14
 Give it a rest for a day then try again… Quoting Hartmut
Schwensen bot@community.openhab.org[4]: hartmood[1] Hartmut
Schwensen[1] December 14 Same Issue here - mutliple attempts,
multiple resets. Still pops up as an unknown devices. Does anybody
have a clue what is the right way to do? BTW: …
 To unsubscribe from these emails, click here[5].
Links:
