- Platform information:
- Hardware:x86-64(intel core i7)/8GB/14TB
- OS: Ubuntu Server 14.04.5 LTS
- Java Runtime Environment: Java SE Runtime 1.8.0_181
- openHAB version: OpenHAB2 latest (apt-get)
- Issue of the topic:
I am trying to send JSON via rules. I have tried searching and copying strategies that others seem to have gotten to work but they are not working for me.
I have tried httprequest route
I have tried curl with executeCommandLine several different ways including removing spaces and replacing with @@, using var to make the curl command hidden from executeCommandLine
I donât understand it because this would be the first rule I have used but all I am trying to send is {âSystemONâ:âonâ} as json format to a local ip address.
full curl command is : curl -H âContent-Type: application/jsonâ -X POST -d â{âSystemONâ:âonâ}â http://192.168.0.253/SystemON
I have sent it with terminal as my user and as openhab user with sudo -u and both work perfectly but for some reason will not work in a rule.
I am hoping someone can explain how and the best way to send this. From an item directly if possible but if not through a rule.
I canât tell if the rule has fired because my logs donât seem to show the button change states for any of my buttons but I know they work because my lights are controlled perfectly fine.
This is for a iZone ducted aircon controller if that helps at all. I couldnât find anything for iZone control anywhere either so on a side note if someone has this setup I would love to know what you have done.
Thanks in advance guys.
