my Name is Peter and I am new to OpenHAB but I am already addicted. Until now I found everything over Forum and the search, but I have a Problem which bothers me a lot.
I use pushover for my Information (e.g. from Homematic), but I cannot get this to work with OpenHAB
I installed pushover over Paper UI and my pushover.cfg is as follows:
I had the same problem but worked it out by debugging through postman.
Create account in Pushover
Create Application/API Token
Create subscription URL for that Application
Subscribe yourself to that application
Take careful note of the parameters when configuring /etc/openhab2/services/pushover.cfg
defaultToken - this is the API token defaultUser - this is not the friendly device key (my mistake) but the user key that you get the from the pushover portal.
Thanks for posting that info @habau it saved me some time, it certainly is confusing with so many keys that are not consistently named. I opted to leave the cfg file alone nothing filled in and instead to do it with each action in the rule…
sendPushoverMessage(pushoverBuilder("Sending GIF from backyard").withApiKey("abcdefg12345").withUser("abcdefg12345").withDevice("MyPhone").withAttachment("/tmpfs/Camera1/ipcamera.gif"))
