Hi team,
I’m on OH3 and I’ struggling to extract certain values from here: https://api.corona-zahlen.org/states/
Therefore I configured this thing based on the HTTP binding:
UID: http:url:a6efe98704
label: Covid Bundesländer
thingTypeUID: http:url
configuration:
authMode: BASIC
ignoreSSLErrors: false
baseURL: https://api.corona-zahlen.org/states/
delay: 0
stateMethod: GET
refresh: 30
commandMethod: GET
contentType: application/json
timeout: 3000
bufferSize: 2048
channels:
- id: weekIncidence_NRW
channelTypeUID: http:number
label: Inzident pro 100k NI
description: null
configuration:
stateTransformation: JSONPATH:$.data[NW].weekIncidence
- id: weekIncidence_NI
label: Inzident pro 100k NRW
description: null
configuration:
stateTransformation: JSONPATH:$.data[NI].weekIncidence
- id: population_NRW
label: Einwohner NRW
description: null
configuration:
stateTransformation: JSONPATH:$.data[NW].population
- id: population_NI
label: Einwohner NI
description: null
configuration:
stateTransformation: JSONPATH:$.data[NI].population
- id: last_update
channelTypeUID: http:datetime
label: last updates
description: null
configuration:
stateTransformation: JSONPATH:$.meta.lastUpdate
In the logs I get this warning:
2021-03-21 07:50:21.104 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.data[NI].weekIncidence', serviceName='JSONPATH'} failed: An error occurred while transforming JSON expression.
2021-03-21 07:50:21.110 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.data[NW].weekIncidence', serviceName='JSONPATH'} failed: An error occurred while transforming JSON expression.
2021-03-21 07:50:21.113 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.data[NI].population', serviceName='JSONPATH'} failed: An error occurred while transforming JSON expression.
2021-03-21 07:50:21.116 [WARN ] [.transform.SingleValueTransformation] - Executing transformation ChannelStateTransformation{pattern='$.data[NW].population', serviceName='JSONPATH'} failed: An error occurred while transforming JSON expression.
and the item receives just NULL:
I validated the JSONPATH ($.data[NI].weekIncidence) using the online validator (http://jsonpath.com/), and it seems to be correct:
I’m wondering, what’s wrong here.
Thanks again for support!
Matthias
