Josar
(Josar)
10
This was meant for a better understanding of things channels items etc, as it is explained there in detail.
You may follow up with this where basically is done what you do.
There is a " missing after the =.
As your command directly returns only the value you can link the output channel directly to the item and it should work, no need for a rule.
