I have a Raspberry Pi that publishes an image via MQTT message to my local MQTT broker (mosquitto). This one bridges the communication to another broker running on an Amazon AWS EC2 instance. Using an MQTT Dashboard app on Android I can view the image while being not at home.
Now I want to integrate this image into the OH dashboard. I have tried to create an item:
Image mqttRaspberryPiImage "Pi Image" {mqtt="<[mosquitto:/raspberrypi/img:state:default]"}
But this leads to the following exception in the log:
2018-02-07 20:15:59.410 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'mqtt' of item 'mqttRaspberryPiImage' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: cannot process unknown item type Image
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.getOpenHABItem(BindingConfigReaderDelegate.java:87) [207:org.openhab.core.compat1x:2.2.0]
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.getOpenHABItem(BindingConfigReaderDelegate.java:57) [207:org.openhab.core.compat1x:2.2.0]
As the stacktrace reveals, I am using OH 2.2.0.
Do I interpret the error message corretly, that the MQTT binding does not support images?
Unfortunately the MQTT dashboard app on my smartphone does not support base64 encoded images. The image has to be in binary raw format in the message body.
Do you have an idea how to solve this?
