[SOLVED] Recommended package installation does not work - openhabian-config: command not found
I setup a new system with an RPI 3 B.
Then I tried to use the following images from raspberry.org:
(same as on the Page)
After waiting of more the 1 hour and a reboot on ssh it is not possible to use the sudo openhabian-config.
I get only the following feedback:
pi@raspberrypi:~ $ sudo openhabian-config
sudo: openhabian-config: command not found
What I am doing wrong?
Holgus
You should have done the openHABian installation if that is what you wanted. Just follow the general Linux install.
I believe you can install openHABian on top of a package installation though. @mstormi please verify.
# install git
sudo apt-get update
sudo apt-get install git
# download and link
sudo git clone https://github.com/openhab/openhabian.git /opt/openhabian
sudo ln -s /opt/openhabian/openhabian-setup.sh /usr/local/bin/openhabian-config
# execute
From https://www.openhab.org/docs/installation/openhabian.html#other-linux-systems-add-openhabian-just-like-any-other-software
