[SOLVED] Resend current item's state
What is the command to re-send the actual state of an item?
My goal is to resend via MQTT the state of some items (relays) when the Arduino board is reconnected to the network (detected by PING via Network Binding).
Actually, I’m using this code:
if (Relay4.state == OFF) && (HabpanelBattery.state == "ECO")  {
                            Relay3.sendCommand(ON) }
Now I want to include the re-sending command into this code:
rule "ping ArduinoSwitchInverter"
when Item ping_192_168_1_10_online changed
    if (ping_192_168_1_10_online.state == ON) {
    logInfo("Alert:", "ArduinoSwitchInverter changed to ON")
//here I want to re-send to Arduino the actual state of item "Relay4"
    else logInfo("Alert: ", "ArduinoSwitchInverter changed to OFF")
I’m focus on using postUpdate(Relay4… ) but I don’t know how to add here the current status of the item involved.
I haven’t tested this but you can try it and see what the logs say.
    var relay_state = Relay4.state
    var new_state = "UNKOWN"
    switch true {
        case relay_state == ON  : new_state = "ON"
        case relay_state == OFF : new_state = "OFF"
    if(relay_state.state != new_state){
		Relay4.sendCommand(new_state)
I’ve updated my code following your instructions:
when Item ping_192_168_1_10_online changed  // test: receive update [<state>] OR receive command [<command>]
    var relay3_state = Relay3.state
    var relay4_state = Relay4.state
    var relay3_new_state = "UNKNOWN"
    var relay4_new_state = "UNKNOWN"
        switch true {
            case relay3_state == ON : relay3_new_state = "ON"
            case relay3_state == OFF: relay3_new_state = "OFF"
            case relay4_state == ON : relay4_new_state = "ON"
            case relay4_state == ON : relay4_new_state = "OFF"
    else if (relay3_state.state != relay3_new_state){
            Relay3.sendCommand(relay3_new_state)
    else if (relay4_state.state != relay4_new_state){
            Relay4.sendCommand(relay4_new_state)
Got this log error:
2019-01-18 15:52:59.401 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'ping ArduinoSwitchInverter': 'state' is not a member of 'org.eclipse.smarthome.core.library.types.OnOffType'; line 22, column 14, length 18
What does the item file look like.
Updated with Relay:
    var Relay3_state = Relay3.state
    var Relay4_state = Relay4.state
    var Relay3_new_state = "UNKNOWN"
    var Relay4_new_state = "UNKNOWN"
        switch true {
            case Relay3_state == ON : Relay3_new_state = "ON"
            case Relay3_state == OFF: Relay3_new_state = "OFF"
            case Relay4_state == ON : Relay4_new_state = "ON"
            case Relay4_state == ON : Relay4_new_state = "OFF"
    else if (Relay3_state.state != Relay3_new_state){
            Relay3.sendCommand(Relay3_new_state)
    else if (Relay4_state.state != Relay4_new_state){
            Relay4.sendCommand(Relay4_new_state)
No more log error… but nothing happened (Relay… no changes & no related log report).
The easiest way would be to persist the topic when the command is sent. Then the arduino would automatically receive the topic and last command when reconnecting.
Relay3_state is already a state, so you shouldn’t do Relay3_state.state in your else if part (same for Relay4), just remove the .state.
Furthermore the else if statements make no sense, they should be just if statements.
Furthermore you should set Relay3_new_state to ON or OFF, not to "ON" or "OFF".
I didn’t notice the else if that was added by the OP.:hushed: Thanks for pointing that out.:+1:
@TomaxMe here’s a link to help with if, else and else if statements.
I keep this bookmarked.:wink:
You have two identical case statements…
        switch true {
I’ve got this error after correcting:
[WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert '' to a state type which item 'Relay4' accepts: [OnOffType, UnDefType].
The corrrected code:
    var Relay3_new_state = ""
    var Relay4_new_state = ""
        switch true {
            case Relay3_state == ON : Relay3_new_state = ON
            case Relay3_state == OFF: Relay3_new_state = OFF
            case Relay4_state == ON : Relay4_new_state = ON
            case Relay4_state == ON : Relay4_new_state = OFF
    if (Relay3_state != Relay3_new_state){
            Relay3.postUpdate(Relay3_new_state)
    if (Relay4_state != Relay4_new_state){
            Relay4.postUpdate(Relay4_new_state)
    var OnOffType Relay3_new_state = NULL
    var OnOffType Relay4_new_state = NULL
Because you first instantiate Relay3_new_state as a string, which you really shouldn’t do, change that into:
As Vincent mentioned above, you have two identical case statements for Relay4
switch true {
H102… I have 4 cases: ON-ON, ON-OFF for each relay.
Update: uhhh… now I’ve saw that. I’ll correct it right now.,
2019-01-18 16:18:54.847 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'ping ArduinoSwitchInverter': An error occurred during the script execution: Could not invoke method: org.eclipse.smarthome.model.script.actions.BusEvent.sendCommand(org.eclipse.smarthome.core.items.Item,org.eclipse.smarthome.core.types.Command) on instance: null
The updated code is:
        switch true {
            case Relay4_state == OFF : Relay4_new_state = OFF
        switch true {
That won’t work, it will only do one of the cases, the first one that watches on the list
replace with:
Relay3_new_state = Relay3_state
Relay4_new_state = Relay4_state
And change:
    var OnOffType Relay3_state = Relay3.state
    var OnOffTypre Relay4_state = Relay4.state
Why so complicated…
        Relay3.sendCommand(Relay3.state.toString)
        Relay4.sendCommand(Relay4.state.toString)
My thoughts exactly when reviewing how this topic has been developing.
However, without .toString :slight_smile:
:slight_smile:
Yeap, it’s working well (changing the relay via MQTT).
Also, I’ve got that error
[WARN ] [rthome.model.script.actions.BusEvent] - Cannot convert 'NULL' to a command type which item 'Relay4' accepts: [OnOffType, RefreshType].
Which one?
