[SOLVED] Restricting access to paperui from only a specified IP address
I secured my site as per the OpenHAB security documentation and so my ngnix config looks as follows:
server {
    listen                          80;
    server_name                     192.168.1.25;
    return 301                      https://$server_name$request_uri;
server {
	listen 443 ssl;
        root /var/www/html;
        index index.html index.htm index.nginx-debian.html;
        ssl_certificate                 /etc/ssl/openhab.crt;
        ssl_certificate_key             /etc/ssl/openhab.key;
	location / {
                proxy_pass                            http://localhost:8080/;
                proxy_set_header Host                 $http_host;
                proxy_set_header X-Real-IP            $remote_addr;
                proxy_set_header X-Forwarded-For      $proxy_add_x_forwarded_for
                proxy_set_header X-Forwarded-Proto    $scheme;
                auth_basic                            "Username and Password Required";
                auth_basic_user_file                  /etc/nginx/.htpasswd;
I want to limit access to my paperui URL so that I can only access it from 192.168.1.51. I therefore added the following location block in; just before the last curly brackets
location ~ paperui {
   allow 192.168.1.51;
   deny all;
This however results in a 404 error whenever I visit https://192.168.1.25/paperui/index.html#/inbox/search (or any link with paperui in it).
I have posted to the nginx forum but had no response so I was hoping that someone with experience with nginx (and understand https://www.openhab.org/docs/installation/security.html more fully) would be able to point me in the right direction.
Nearly there I think. The below gives me the correct 403 response. If I however add
allow 192.168.1.51
I then get a 404 error.
I think it has something to do with the reverse proxy.
location ^~ /paperui/ {
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
deny all;
auth_basic “Username and Password Required”;
I got it working, there was a trailing “/” that I needed to remove from the proxy_pass entry
Here is the final config file
server {
    listen                          80;
server {
        listen 443 ssl;
        root /var/www/html;
        location / {
                proxy_pass                            http://localhost:8080;
        location ^~ /paperui {
                allow 192.168.1.51;
                deny all;
Now that I know how this works, I will change it so that only the BasicUI is allowed, the HABPanel is accessed via whitelisted devices and paperui only from one or two other devices.
Don’t forget to allow access to the rest API (location = /rest), otherwise none of the uis will work.
My config looks as follows and it all appears to be working:
server {
    listen                          80;
server {
	listen 443 ssl;
        root /var/www/html;
	location / {
		include shared_1.conf;
	location /paperui/ {
		include shared_2.conf;
	location /homebuilder/ {
	location /habmin/ {
	location /doc/ {
shared_1.conf is
And shared_2.conf is
allow 192.168.1.51;
deny all;
I was hoping to do something like
location ~ index { .......
As this would have blocked everything except basicui but it would not work with proxy_pass and so I settled with the above.
Yes that works, since /rest is handled by /. But if you should allow only basicui and block everything else, it wouldn’t work.
Aagh, understood.. thanks :slight_smile:
Changed the locations to
location / {
	location /basicui/ {
This allows 192.168.1.52 to access anything but everyone else to only access basicui
I will ultimately create a whilelist for habpannel
And that’s when you need to allow everyone access to the rest API.
	location /rest/ {
When you start basicui it connects to the rest api in the background to get the sitemap and all item states. If that connection is blocked nothing will work.
Perfect; I am now totally sorted.. thanks
