I am building a room automation system which has just lights and rollershutters.
I started with only lights for now but I am unable to configure OpenHAB.
I am able to read and write the bus which means my KNXD is working.
But I am unable to configure openHAB.
My openhab.cfg file on /etc/openhab/configurations path is as follows:
org.eclipse.smarthome.core.persistence
org.eclipse.smarthome.core.library.types
org.eclipse.smarthome.core.library.items
org.eclipse.smarthome.model.script.actions
rule "Switch ON Left Lights 1"
Item Left_Lights changed [from OFF] [to ON]
Left_Lights.sendCommand(ON)
rule "Switch ON Right Lights 2"
Item Right_Lights changed [from OFF] [to ON]
Right_Lights.sendCommand(ON)
rule "Switch ON Centre Lights"
Item Centre_Lights changed [from OFF] [to ON]
Centre_Lights.sendCommand(ON)
rule "Switch ON Other Lights"
Item Other_Lights changed [from OFF] [to ON]
Other_Lights.sendCommand(ON)
rule "Switch OFF Left Lights 1"
Item Left_Lights changed [from ON] [to OFF]
Left_Lights.sendCommand(OFF)
rule "Switch OFF Left Lights 2"
Item Right_Lights changed [from ON] [to OFF]
Right_Lights.sendCommand(OFF)
rule "Switch OFF Centre Lights"
Item Centre_Lights changed [from ON] [to OFF]
Centre_Lights.sendCommand(OFF)
rule "Switch OFF Other Lights"
Item Other_Lights changed [from ON] [to OFF]
Other_Lights.sendCommand(OFF)
Also, I have another doubt... My etc directory has 2 sub-directories openhab and openhab2. Is it normal?
No. Most likely you have installed in parallel OH1 & OH2
Get rid of the OH1 installation and use OH2 config files (for example: openhab.cfg is used in OH1)
For OH2, you should use /etc/openhab2/...) (e.g. /etc/openhab2/services/knx.cfg)
To learn how to use the forum, send a message to @discobot with the subject “start new user” and “start new user” in the text box then follow the chat
import org.eclipse.smarthome.core.items
import org.eclipse.smarthome.core.persistence
import org.eclipse.smarthome.core.library.types
import org.eclipse.smarthome.core.library.items
import org.eclipse.smarthome.model.script.actions
rule "Switch_ON_LeftLights1"
Item demoSwitch1 changed from OFF to ON
demoSwitch1.sendCommand(ON)
rule "Switch_ON_LeftLights2"
Item demoSwitch2 changed from OFF to ON
demoSwitch2.sendCommand(ON)
rule "Switch_ON_LeftLights3"
Item demoSwitch3 changed from OFF to ON
demoSwitch3.sendCommand(ON)
rule "Switch_ON_CentreLights"
Item demoSwitch4 changed from OFF to ON
demoSwitch4.sendCommand(ON)
rule "Switch_ON_OtherLights"
Item demoSwitch5 changed from OFF to ON
demoSwitch5.sendCommand(ON)
rule "Switch_OFF_LeftLights1"
Item demoSwitch1 changed from ON to OFF
demoSwitch1.sendCommand(OFF)
rule "Switch_OFF_LeftLights2"
Item demoSwitch2 changed from ON to OFF
demoSwitch2.sendCommand(OFF)
rule "Switch_OFF_LeftLights3"
Item demoSwitch3 changed from ON to OFF
demoSwitch3.sendCommand(OFF)
rule "Switch_OFF_CentreLights"
Item demoSwitch4 changed from ON to OFF
demoSwitch4.sendCommand(OFF)
rule "Switch_OFF_OtherLights"
Item demoSwitch5 changed from ON to OFF
demoSwitch5.sendCommand(OFF)
2018-07-26 09:33:19.958 [me.event.ThingUpdatedEvent] - Thing 'knx:serial:bridge' has been updated.
2018-07-26 09:33:19.961 [hingStatusInfoChangedEvent] - 'knx:serial:bridge' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): failed to open serial port /dev/knx1
This is the error I am getting.
KNXD works fine as I am able to read and write the bus using vbusmonitor1 and groupswrite
