Hello everybody,
am new in Openhab/Zwave, and i need some help.
I started to use zwave with ZMEEUZB1 on the server, and some door sensors from the EZW line. (battery powered) Everything is working fine, the sensors are connected to the server. After that i have recognised, that i will have some signal problem because of the distance, i installed fibaro fgr222 roller shutters. (AC powered). My plan was that the AC powered roller shutters will act as “routing slave”, and from the server i willl reach the doors sensors over the roller shutters. I installed the roller shutters, they work fine as well, i waited 1 day to rebuild the mesh, but now in the morning i have seen, that every devices are directly connected to the server, and the roller shuttters are not working as “routing slave”.
My questions are:
- Is it normal, that the FGR222 are not working as routing slave?
- If no, where should i start with the debugging?
- If yes, can you please propose me some zwave devices (function doesnt matter) which are able to route?
Thanks a lot for your help in advance!
