[SOLVED] Rule ' ': Could not cast value to float
Okay,to display data in your UI it will always need to end up in an Item. So that decision is made for you.
For your simple rule, you probably could just get rid of all the variables and work with Items directly, Remembering that it is Item states you are interested in.
slowly I despair… :neutral_face:
I get this log error:
2020-01-30 20:40:01.256 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Min/Max temp’: Could not cast NULL to java.lang.Number; line 23, column 48, length 33
My rule:
//calculate Min/Max value of the GenMQTTThingRoom temperature
// var Number Room1TempTodayMin = 0.0
// var Number Room1TempTodayMax = 0.0
// var DateTime Room1TempTodayMin_Time
// var DateTime Room1TempTodayMax_Time
rule "Min/Max temp"
    Item GenMQTTThing_Room1_temp changed
//calculate max temp
if ( GenMQTTThing_Room1_temp.state as Number > Room1TempTodayMax.state as Number) {
    Room1TempTodayMax.postUpdate(GenMQTTThing_Room1_temp.state as Number)     //updating the item Room1TempTodayMax
    Room1TempTodayMax_Time.postUpdate(new DateTimeType)     //updating the item Room1TempTodayMax_Time
    logInfo("Calculate temp Max YES!")
}   else
     logInfo("Calculate temp Max NO!")
the items:
Number      Room1TempTodayMin       "Room1TempTodayMin [%.1f °C]"  <heating>
Number      Room1TempTodayMax       "Room1TempTodayMax  [%.1f °C]"  <heating>
DateTime      Room1TempTodayMin_Time       "Room1TempTodayMin_Time [%1$tH:%1$tM]"  <heating>
DateTime     Room1TempTodayMax_Time      "Room1TempTodayMax_Time [%1$tH:%1$tM]"  <heating>
How can I initalize the item: Room1TempTodayMin, Room1TempTodayMax?
rule "Startup"
    System started
    if (Room1TempTodayMax.state == NULL)    {
        Room1TempTodayMax.postUpdate(0)
That should work.
Or you could do it in your main rule,the first time you call it. Test for NULL state before using, and just go ahead and do the update without further comparisons.
Later, perhaps you’ll want to make another rule to reset your daily min/max at midnight.
@vzorglub, @H102, @opus, @rossko57:
Thank you so much for our willingness to help, patience,and kindness!
