does anybody have an idea why this rule doesn’t work? The “if”-condition seems to be the problem.
rule "Heizung Bad Boost"
Item Temp_Bad_soll received update
if (Temp_Bad_soll.state == 28) {
sendTelegram("bot1", "Die Heizung im Bad wurde für 45 min auf 28 °C gestellt.")
createTimer(now.plusMinutes(45), [|
Temp_Bad_soll.sendCommand(24)
sendTelegram("bot1", "Die 45 min sind vorüber; Heizung jetzt bei 24 °C.")
Just had a look for the dimension issue and found this thread:
Is it possible, that the rule doesn’t work anymore since the OH 2.5 update?
Otherwise: what would you recommend how to change the if-condition concerning the dimension?
I’m not on 2.5, but have seen this in 2.4 as well.
syntax is something like: (I have not tested below)
if (Temp_Bad_soll.state == 28|°C)
I would suggest to check your actual Item state. Write a line to your log before the if condition and see whats exactly in the item state. for instance:
Why don’t you display the value of Temp_Bad_soll with a logInfo()?
Or look in events.log and see what’s happening to it?
And then share your result.
Everything here is guesses, because only you have that information.
Improve the quality of the help you seek .
