i have two lights, which i want to turn on and off with a single button (virtual item called livingroomLights) in the dashboard (rule LivingRoom)
If only one lamo is still turned on, the button has to be switched on. If bothlamps turned off, the button has to be switched off (rule LivingRoomSwitch).
My Problem is that both rules mutually influence each other. I thought that postUpdate do not change other rules.
Can somebody help with this problem?
rule "LivingRoom"
Item livingroomLights received command
if(livingroomLights.state == OFF){
logInfo("Rule LivingRoom", "livingroomLights.state == OFF");
tradfri_0220_gwa03c2e6d394c_65537_brightness.sendCommand(OFF);
tradfri_0220_gwa03c2e6d394c_65538_brightness.sendCommand(OFF);
else if(livingroomLights.state == ON){
logInfo("Rule LivingRoom", "livingroomLights.state == ON");
tradfri_0220_gwa03c2e6d394c_65537_brightness.sendCommand(ON);
tradfri_0220_gwa03c2e6d394c_65538_brightness.sendCommand(ON);
rule "LivingRoomSwitch"
Item tradfri_0220_gwa03c2e6d394c_65537_brightness received command or
Item tradfri_0220_gwa03c2e6d394c_65538_brightness received command
if(tradfri_0220_gwa03c2e6d394c_65537_brightness.state instanceof PercentType || tradfri_0220_gwa03c2e6d394c_65538_brightness.state instanceof PercentType){
val b1 = tradfri_0220_gwa03c2e6d394c_65537_brightness.state as Number;
val b2 = tradfri_0220_gwa03c2e6d394c_65538_brightness.state as Number;
if(b1 > 0 || b2 > 0){
livingroomLights.postUpdate(ON);
if(b1 == 0 && b2 == 0){
livingroomLights.postUpdate(OFF);
postUpdate() should not trigger received command. Be aware that there are some small issues:
rule "LivingRoom"
logInfo("Rule LivingRoom", "livingroomLights received command {}",receivedCommand.toString)
if(receivedCommand == OFF) { // either OFF or ON
} else {
Item tradfri_0220_gwa03c2e6d394c_65537_brightness changed or
Item tradfri_0220_gwa03c2e6d394c_65538_brightness changed
val b1 = if(tradfri_0220_gwa03c2e6d394c_65537_brightness.state instanceof Number)
else
0
val b2 = if(tradfri_0220_gwa03c2e6d394c_65538_brightness.state instanceof Number)
else
0
if(b1 + b2 > 0) {
} else {
Please don’t use a semicolon ( ; ) after a command. If using received command as a trigger, better use the receivedCommand implicit var to react to the command, openHAB is asynchronous and there is a good chance that the state is not already the new state.
As the Item is of type Switch, the received command can either be ON or OFF (not NULL, this is no command but only a state!), so you don’t need to check over and over again.
For the second rule, I changed the trigger to changed, as this is more appropriate to the task.
Testing the state type for PercentType is ok, but Number would suffice, but it’s not ok only to test if one of two item states is of type PercentType and then forcing a type Number for both of them
I used an ternary operator, val a = if (z == y) b else c, this is: if true, use b, if false, use c
Last but not least, as b1 and b2 are numbers between 0 and 100, it’s sufficent to add them and check for 0.
You could actually do that part with a Group instead of the first rule
Group:Switch:OR(ON,OFF) livingroomLights “Texty label”
and put the tradfri Items in that group
The Group automatically passes commands through to member Items
I did a test and now it works as plannend. I think it was the hint for the implicit variable and the trigger event change from received command to changed
If i use received command as trigger, postUpdate will trigger the rule!
rule "recvCmd"
Item btn received command
if(receivedCommand == OFF){
logInfo("Rule recvCmd", "livingroomLights.state == OFF")
allLightsBrightness.sendCommand(OFF)
allLightsBrightness2.sendCommand(OFF)
else{
logInfo("Rule recvCmd", "livingroomLights.state == ON")
allLightsBrightness.sendCommand(ON)
allLightsBrightness2.sendCommand(ON)
rule "postUpdate"
Item allLightsBrightness received command or
Item allLightsBrightness2 received command
if(allLightsBrightness2.state instanceof Number || allLightsBrightness.state instanceof Number){
val b1 = allLightsBrightness.state as Number
val b2 = allLightsBrightness2.state as Number
if(b1 + b2 > 0){
logInfo("Rule postUpdate", "btn.postUpdate(ON)")
btn.postUpdate(ON)
else{
logInfo("Rule postUpdate", "btn.postUpdate(OFF)")
btn.postUpdate(OFF)
Start with “all off”:
==> events.log <==
2018-11-24 00:03:36.369 [ome.event.ItemCommandEvent] - Item 'btn' received command ON
2018-11-24 00:03:36.390 [vent.ItemStateChangedEvent] - btn changed from OFF to ON
==> openhab.log <==
2018-11-24 00:03:36.391 [INFO ] [.smarthome.model.script.Rule recvCmd] - livingroomLights.state == ON
==> events.log <==
2018-11-24 00:03:36.405 [ome.event.ItemCommandEvent] - Item 'allLightsBrightness' received command ON
2018-11-24 00:03:36.422 [ome.event.ItemCommandEvent] - Item 'allLightsBrightness2' received command ON
==> openhab.log <==
2018-11-24 00:03:36.441 [INFO ] [arthome.model.script.Rule postUpdate] - btn.postUpdate(OFF)
2018-11-24 00:03:36.447 [INFO ] [arthome.model.script.Rule postUpdate] - btn.postUpdate(OFF)
==> events.log <==
2018-11-24 00:03:36.450 [vent.ItemStateChangedEvent] - allLightsBrightness changed from 0 to 100
2018-11-24 00:03:36.457 [vent.ItemStateChangedEvent] - allLightsBrightness2 changed from 0 to 100
2018-11-24 00:03:36.460 [vent.ItemStateChangedEvent] - btn changed from ON to OFF
