I’m trying to run a python script from the exec binding, it does seem to be running (it has stopped erroring in the logs) but i suspect the python is failing due to be unable to find a module
When I run the python with this
sudo -u openhab python3.5 Nearest360.py
Traceback (most recent call last):
File "Nearest360.py", line 4, in <module>
import requests
ImportError: No module named 'requests'
This runs fine using the openhabian user from the command line.
I have installed the library using pip on the openhabian user, this is specific to using the openhab user, I am investigating python forums also but suspected someone over here may have come across a similar error and solved it.
Please see my answer to your question in the thread about the bmw connected python script.
You installed the request module for Python 2.7 instead of Python 3.
The bmw python script uses Python 3 and you need to install the request module with pip3.
