Please click the square box (lower right corner after clicking the three dots … ) on the post that provided the solution and edit the title to start with [Solved].
Example:
I’m not a Windows user so my help will be limited with how you need to map your drive but the error is complaining about the name. Have you used something like netstat -n -a from the command line to list all connections and names? You can also install TCPview if you prefer a GUI interface.
If the above doens’t help do a google search for something like how to map windows drives as this is not really an OH issue but a Windows Config issue.
