I have just is installed openhabian on an Intel NUC i5 running ubuntu server 16.04
Every is working 100% and installed without any issues. AWSOME!!
The issue still be be addresses is my samba shares. I can see the shares on my mac but it is read only.
Should like an easy fix, but I just cannot resolve it.
Details:
- I installed ubuntu server and created an ‘opehabian’ user account during the install process.
- I installed all components including samba via the openhabian-config
- I used option 14 ‘fix permissions’ to correctly set permissions
- Permissions look ok to me, but I am still learning?
drwxrwxr-x+ 15 openhab openhabian 4096 Mar 27 15:41 .
drwxr-xr-x 100 root root 4096 Mar 27 21:37 ..
drwxrwxr-x+ 8 openhab openhabian 4096 Mar 29 16:46 .git
-rw-rw-r-- 1 openhab openhabian 22 Mar 27 15:41 .gitignore
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 27 15:41 html
drwxrwxr-x+ 3 openhab openhabian 4096 Mar 26 20:24 icons
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 28 15:47 items
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 27 15:41 persistence
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 27 19:30 rules
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 27 15:41 scripts
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 27 19:12 services
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 27 18:56 sitemaps
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 26 20:24 sounds
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 28 15:48 things
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 27 15:41 transform
drwxrwxr-x+ 2 openhab openhabian 4096 Mar 27 15:41 .vscode
Currently:
- I am still only getting read only access to all my shares.
- I am connecting as ‘openhabian’
I used option 34 within the openhabian-config to change the samba password. This seams to be successful, but it does not seam to change as mac will not even connect. (wrong password).
I had to use the ‘sudo smbpasswd -a openhabian’ command, and set a new password. Only then will the mac even connect (but read only)
Any advice will be appreciated.
My previous installation was on a openahabian image for pi and that work 100%. Something I am missing during the openhabian manual install on ubuntu server 16.0.4?
Thank you so so much!!
