Hi all,
I’ve just updated from OH2 to OH3 my setup, but I’ve just discovered that OH1 samsungAC binding is not present anymore (why I haven’t read the documentation before pressinf upgrade button
I’ve tried to install the binding just putting the jar file into /usr/share/openhab/addons , but I get this error:
2021-01-17 09:36:27.490 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.samsungac-1.14.0.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.samsungac [270]
Unresolved requirement: Import-Package: org.openhab.model.item.binding
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [bundleFile:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [bundleFile:3.6.4]
Is there a chance that somewhere in time this binding will be supported in OH3 or there is some sort of workaround to be applied, or I should consider to revert to OH2?
Thanks!
