Dear,
I installed Satel binding 2.3, but my log says this (looping):
2018-09-23 22:27:43.062 [INFO ] [.satel.internal.protocol.Ethm1Module] - Closing connection to ETHM-1 module
2018-09-23 22:27:44.029 [INFO ] [.satel.internal.protocol.Ethm1Module] - Connecting to ETHM-1 module at 192.168.1.60:7094
2018-09-23 22:27:44.036 [INFO ] [.satel.internal.protocol.Ethm1Module] - ETHM-1 module connected successfully
2018-09-23 22:27:44.045 [ERROR] [.satel.internal.protocol.SatelModule] - Unexpected exception occurred during writing a message
java.net.SocketException: Broken pipe (Write failed)
at java.net.SocketOutputStream.socketWrite0(Native Method) ~[?:?]
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111) [?:?]
at java.net.SocketOutputStream.write(SocketOutputStream.java:134) [?:?]
at org.openhab.binding.satel.internal.protocol.SatelModule.writeMessage(SatelModule.java:311) [222:org.openhab.binding.satel:2.3.0]
at org.openhab.binding.satel.internal.protocol.SatelModule.communicationLoop(SatelModule.java:375) [222:org.openhab.binding.satel:2.3.0]
at org.openhab.binding.satel.internal.protocol.SatelModule.access$1(SatelModule.java:345) [222:org.openhab.binding.satel:2.3.0]
at org.openhab.binding.satel.internal.protocol.SatelModule$CommunicationWatchdog$2.run(SatelModule.java:480) [222:org.openhab.binding.satel:2.3.0]
2018-09-23 22:27:44.052 [INFO ] [.satel.internal.protocol.Ethm1Module] - Closing connection to ETHM-1 module
I’ve not idea about the origin of problem…
EDIT:
The problem was of satel binding 1.x active on my OH. Now I removed it and I work with 2.3 binding module only
