- Platform information:
Raspberry Pi 3B+ with openhabian 1.5 and OH 2.5.3 stable
I have a rule looking up the human readable adress for a geolocation.
For some fixed items (Home & Work Location) I would like to skip this.
However, because Location data is not persisted, I would like to initialize the human readable location for these just once.
This is the according rule:
rule "Lookup Address for Geolocations"
Member of G_Loc changed
val itemName = triggeringItem.name.toString // geo location item
var location = triggeringItem.state.toString // geo location item state
var String itemNameStr = itemName + "_Str" // human readableaddress item
val itemStrState = ScriptServiceUtil.getItemRegistry.getItem(itemNameStr).state // state of the human readable address
logInfo("+++ GEOFENCING", "Location update: " + itemName + ": location: >" + location + "<")
// skip processing for some Locations
if(itemName == "Loc_Home" || itemName == "Loc_Work") {
// just end here if the initial address lookup for fixed locations (home / work) has not been done
logInfo("+++ GEOFENCING", "Location_Str of item " + itemNameStr +" +++++ DEBUG +++++ itemStrState: >" + itemStrState + "<")
if(itemStrState != NULL) { // does this work with state NULL to String: "NULL" / "" did not work
logInfo("+++ GEOFENCING", "G_Loc changed - " + itemName + " Address eval skipped")
return; // failing fast
I get the following errors:
2020-04-11 16:23:49.504 [INFO ] [marthome.model.script.+++ GEOFENCING] - Location_Str of item Loc_Home_Str +++++ DEBUG +++++ itemStrState: >NULL<
2020-04-11 16:23:49.504 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.Timer 16 2020-04-11T16:23:49.182+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedu$
logInfo(<XStringLiteralImpl>,<XStringLiteralImpl>)
! <XMemberFeatureCallImplCustom>
<XFeatureCallImplCustom>.postUpdate(<XConstructorCallImplCustom>)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@14bd53f (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@d86c31 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1515843 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1779762 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@12e40e (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@c0eb22 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@12a40e5 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@fa89de (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1a931ce (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@8fa4a0 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@e7deb2 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1ee4ac8 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@f4343f (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1483c20 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@19b3d5 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@edb0d5 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@1b3190d (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@b9cda4 (conditionalExpression: false)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@66a112 (conditionalExpression: false)
So my question is:
If the state of the item for the Human readable address (Loc_Home_Str) is not initialized (NULL), how to check this?
With ScriptServiceUtil I retrieve the state of Loc_Home_Str as a String, so shouldn’t it be:
if(itemStrState != NULL) ?
I also tried
if(itemStrState != "NULL")
and
if(itemStrState != "")
None of these seem to work
