rossko57
(Rossko57)
April 11, 2020, 7:09pm
2
This a timer failure. If you’ve just been editing a rules file with other rules that launch timers, you probably ran into the nuisance only “orphaned timer” thing.
That looks like the sort of report you get from orphaned Timers - typically, a long running timer was spawned by a rule, and the rule file was later edited on other business.
When the rule file reloads, the context for the waiting timer is destroyed - but the quartz scheduled timer job is not. Maybe hours later, the now “orphaned” timer code executes and usually fails with a NullPointerException because some variable it references no longer exists.
