[SOLVED] Sending notification when a device changing its state
Evening,
I would like to send notification via openhab app when a device changes a state.
For example this item as below:
Light_GF_Living_Ceiling
I got this rule, but it does not behave as expected. What am I missing here ?
rule “Lamp ON notification”
    Item Light_GF_Living_Ceiling.state changed from OFF to ON
    sendNotification("andy.xxxx@gmail.com", “Test”)
    sendBroadcastNotification("Test")
.state
is not needed when defining a item trigger for your rule.
Try:
Item Light_GF_Living_Ceiling changed from OFF to ON
Tried this suggestion above but still not firing notification.
Any other clues ?
Any clue in the logs?
And your cloud connection is set up correctly?
Yes, it is complaining about that rule -
no viable alternative at input.
2019-01-14 22:52:43.636 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.rules' has errors, therefore ignoring it: [167,6]: no viable alternative at input '“'
Check your quote marks.
Thanks, corrected and works now - solved :wink:
